Michael Johnson
June 1, 2007
Dave says the first upgrades he performed on his GT included a polished stock intake and a cold-air kit. "From roughly 20 minutes of work for the cold-air intake install, I felt more confident in that I could do what needed to be done to the car." Dave installed the Vortech A-Trim supercharger, 30-lb/hr injectors, and 75mm mass air meter himself, but the car didn't run right until SCT reps got their hands on it at a Late Model Mustang Club of Connecticut (www.lmmc-ct.com) dyno day. "I drove the car in feeling like it was missing a couple cylinders; after five minutes on the dyno, it ran like a dream," Dave says. With the stock heads still in place and through the AOD, this car made 295 hp and 330 lb-ft of torque to the wheels. But both numbers are now more than 400, thanks to Edelbrock Performer heads with Ford Racing Performance Parts' 1.6 roller rockers, a Professional Products Typhoon intake, 42-lb/hr injectors, and a Lightning 90mm mass air. And how could we forget the Optima red top battery to get everything started and the Fluidyne radiator to keep it cool. By the time you read this, there will be more to start and keep cool, thanks to the addition of a Vortech S-Trim Supercharger, which is a step up from the A-Trim. This upgrade necessitates a transmission swap to a 4R7OW.
Dave says he didn't begin modifying the interior until 2002, and its first mod was a pair of custom Cerullo XR seats. "I'd say the seats were one of the best modifications I've ever done," Dave says. "For a convertible, you can't beat them as far as looks go, and they're comfortable." A lot of what Dave added inside has to do with gauges. The drop-top boasts Auto Meter Phantom and Ultra-Lite gauges, BBK white-face gauges in the cluster, and a Speed of Sound dash gauge pod. Other interior dress-ups include Mach 1 pedals and custom door panels. At one time, Dave's GT featured a simple 12-inch sub sitting in the trunk with an amp hooked to it, but he has cleaned up his audiophile habit with a custom trunk enclosure for the Rockford Fosgate sub and a Kenwood Excelon 600-watt amp. Inside the cockpit resides a Kenwood head unit, Infinity Reference door speakers, and JBL tweeters.
ENGINE AND DRIVETRAINIgnition
BlockStock, Crane Cams coil, FRPP
Stock9mm spark plug wires, Autolite
Displacementspark plugs
302ciGauges
Rotating AssemblyAuto Meter Phantom and
StockUltra-Lite
Camshaft
StockSUSPENSION AND CHASSIS
Cylinder HeadsFront Suspension
Edelbrock Performer 6037,K-member
1.{{{90}}}/1.60 valves, FRPP 1.6 rollerStock
rockersControl Arms
Intake ManifoldStock
Professional Products TyphoonCaster/Camber Plates
Throttle BodyMaximum Motorsports
Accufab 70mmSprings
Mass AirMAC progressive-rate
Lightning 90mm, K&N filterStruts
Power AdderBilstein heavy-duty
Vortech A-Trim, 2.95-in pulley,Brakes
Anderson Ford MotorsportSN-95 conversion using Bullitt
Power Pipecomponents
Fuel SystemWheels
Walbro 255-lph fuel pump, Kirban'99 Cobra, 17x8-in, chrome
fuel pressure regulator, FRPPTires
42-lb/hr injectors, stock lines andYokohama 235/45
railsRear Suspension
ExhaustSprings
BBK 1 5/8-in ceramic-coatedMAC progressive-rate
short-tube headers, BBK high-Shocks
flow H-pipe, MAC after-cat withBilstein heavy-duty
Flowpath mufflersControl Arms
TransmissionStock
Stock AODBrakes
Rearend'95 GT disc
8.8, stock differential, '95 CobraWheels
axles, 3.73 gears'99 Cobra, 17x8-in, chrome
 Tires
ELECTRONICSGoodyear {{{Eagle}}} 245/45
Engine ManagementChassis Stiffening
Stock computer, SCT tune-upCustom full-length subframe
 connectors
