Michael Johnson
April 19, 2007
Steeda Autosport springs reside at each corner to bring the coupe closer to earth, helping the chrome '99 Cobra wheels fill the gaps. Nitto 555 Extreme ZR 245/45 radials ride shotgun, while Mickey Thompson E/T Street radials bite for traction out back. The Cobra wheels hide Cobra brakes with Mach 1 calipers up front and Cobra brakes out back.
The interior of Paul's coupe boasts '94-and-up GT cloth seats, Steeda Autosports white-face gauges, an FRPP shift knob, and a leather parking-brake boot. Like Joe's Mach, Paul's coupe also has a Steeda Autosports Tri-Ax shifter protruding through the tunnel.
MG Race Engines built a sweet 306 with D.S.S. Trick Flow-specific pistons to mate the short-block to Twisted Wedge heads, which Paul's dad, Gene, treated to a port job prior to being flowed and assembled by Bennett Racing. The heads feature 2.02/1.60 valves and Comp valvesprings, and Comp Pro Magnum 1.6 roller rockers. Paul paired the Trick Flow heads with a Holley SysteMAX II intake with a BBK/Edelbrock 70mm throttle body and a C&L Performance 76mm mass air meter with a Trueflow intake pipe.
ENGINE AND DRIVETRAINELECTRONICS
BlockEngine Management
Stock 5.0Stock A9L computer
DisplacementIgnition
306ciMSD 6A, Blaster TFI coil,
Rotating AssemblyFRPP 9mm spark-plug wires,
Stock crankshaft andAutolite spark plugs
connecting rods, D.S.S.Gauges
Racing Engines Trick Stock, Steeda Autosports
Flow-specific pistons,white-face overlay
Sealed Power piston rings
CamSUSPENSION AND CHASSIS
Comp Cams custom groundFront Suspension
to Bennett Racing specsK-member
HeadsStock
Trick Flow Twisted Wedge,Control arms
owner-ported, flowed andStock
assembled by Bennett Racing,Springs
2.02/1.60 valves, Comp CamsSteeda Autosports Sport Comp
Pro Magnum roller rockersStruts
and valvesprings, FRPP liftersKYB GR-2
IntakeCaster/Camber
Holley SysteMAX IISteeda Autosports, and bump-
Throttle Bodysteer kit
BBK/Edelbrock 70mmBrakes
Mass Air'94-up 13-in Cobra, '03 Mach 1
C&L Performance 76mm withcalipers
Trueflow inlet pipeWheels
Power Adder'99 Cobra 17x8 chrome
Paul's right footTires
Fuel SystemNitto 555 Extreme 245/45/17
Walbro 255-lph fuel pump,Rear Suspension
stock fuel lines, rails, andSprings
injectors, Aeromotive fuel-Steeda Sport Comp
pressure regulatorShocks
ExhaustKYB Gas-a-Just
JBA Headers 1 5/8-in short-Control arms
tube headers, MAC 2 1/2-in Steeda Autosports
ProChamber H-pipe and Brakes
after-cat'94-up 11.65-in Cobra
TransmissionWheels
Stock T5, Ram clutch, '99 Cobra 17x8 chrome
Steeda Tri-Ax shifter, Tires
FRPP shifter knobMickey Thompson E/T Street
DriveshaftChassis Stiffening
FRPP aluminumSteeda Autosports full-length
Rearendsubframe connectors
8.8, 4.30 gears
