5.0 Mustang & Super Fords
2004 Ford Mustang GT - Quality Time
Jonathan Pavia Spends His Winter Weekends At The Dragstrip With This '04 Mustang GT
Horse Sense: Jonathan Pavia is a quality monitor for Rockwell Collins, headquartered in Cedar Rapids, Iowa. He works at the location in his hometown of Melbourne, Florida.
In Florida, we have several entertainment venues competing for our time and, more importantly, our money. No matter what part of Florida one resides, the beach is no more than two hours away. In Orlando, there's Disney World, Wet n' Wild, Sea World, and so on. In Tampa, there's Busch Gardens, Adventure Island, Channelside, Ybor City, and more. South Florida has Miami, South Beach, and a completely different cultural blend. We have championship-winning college and professional teams from Tallahassee to Miami. As Floridians, we have so much entertainment at our disposal, going to the dragstrip doesn't usually rank at the top of many people's destinations-especially in the summer.
But go to any quarter-mile dragstrip in Florida on a test 'n' tune, and you'll see we still make time for racing. If you've visited Orlando Speedworld or Bradenton Motorsports Park, you've probably seen Jonathan Pavia with his '04 Mustang GT. If not, you can see it here.
"I purchased my car brand-new in 2002 from Kelly Ford in Melbourne," Jonathan says. "I went to work with performance upgrades on day one." Like many Mustangs, Jonathan's had nitrous relatively quickly, which led him to the dragstrip with Mustang and LS1 friends. Even though we're fairly sure nitrous installation voided the factory warranty, once it was up, Jonathan added a pair of Total Engine Airflow Stage 2-ported PI heads with what Jonathan refers to as "out of this world" VT Competition Engines' Stage 2 camshafts. With the improved intake capacity, Jonathan knew the bottleneck would be the exhaust, so he swapped out the stock stuff in exchange for Flowtech long-tube headers with the corresponding X-shape crossover and finished with a pair of Flowmaster mufflers.
For those of you wanting to add long-tube headers to your '99-or-newer Mustang GT, Jonathan would like to thank Rick Crane for the use of his lift. Rick's lift allowed Jonathan enough room to drop his K-member, making it easier to install the long-tube headers. The work was worth it. "I wish there was a way to put a sound clip in this article so readers can hear this combo themselves," Jonathan says. Trust us-we heard it and can vouch for its demonic demeanor.
Speaking of seeing this combo in person, Jonathan tries to make it to the dragstrip as much as possible in the winter. We know it's the opposite up north, but while northerners are digging out of the snow, we Floridians are at the track. The winter is the best because one bad aspect of Florida is that it rains nearly every summer afternoon, making trips to the track worthless unless it's a RunDay Sunday at Bradenton.
Even though Jonathan's main source of enjoyment comes from racing, his car is just as much at home on the show field or at the local cruise-in, and he has the trophies to prove it. From a Most Improved Driver award at Bradenton Motorsports Park to a People's Choice trophy at the Fun Ford Weekend Orlando event, Jonathan makes time to enjoy his Mustang.
Several interior-trim pieces were treated to Laser Red to add contrast to the spartanly appointed cabin. Using the just-tell-me-what-I-need-to-know method, Jonathan's GT boasts a simple Auto Meter Monster tach and a Lunar-series gauge cluster. His shifter arrangement is an interesting one. He utilizes a stock shifter with a short handle and an '05-'06 Mustang GT-style knob.
Even if one can see the Nitrous Express 150hp wet nitrous system's solenoids, there's little available to the naked eye that would give away any performance advantage. But lurking under the factory cam covers is a pair of Total Engine Airflow-ported heads, VT Competition Engines' Stage 2 camshafts, Comp Cams valvesprings, and ModMax valves. An SVT Focus fuel pump and Ford Racing Performance Parts 30-lb/hr injectors provide the fuel while Flowtech long-tube headers, an X-shape crossover, and Flowmaster mufflers blow it out from just in front of the rear axle. Tuning is done via an SCT XCalibrator handheld flash tool. In the muggy Florida heat, Jonathan runs 11.70s at 120 mph with a 1.69 60-foot time.
ENGINE AND DRIVETRAIN | Ignition |
Block | Stock ignition, NGK TR6 |
Stock | spark plugs |
Displacement | Gauges |
281ci | Auto Meter Monster tach, |
Crank | Auto Meter Lunar-series |
Stock | gauge cluster |
Rods |   |
Stock |   |
Pistons | SUSPENSION AND CHASSIS |
Stock | Front Suspension |
Cylinder Heads | K-member |
Total Engine Airflow Stage | Stock |
2-ported PI heads, ModMax | Control Arms |
valves, Comp Cams Beehive | Stock |
valve springs | Caster/Camber Plates |
Camshafts | MAC Performance |
VT Competition Engines Stage 2, | Springs |
naturally aspirated | {{{Fox}}} Mustang four-cylinder |
Intake Manifold | Struts |
Stock | Lakewood {{{90}}}/10 |
Mass Air Meter | Brakes |
Stock | Stock |
Power Adder | Wheels |
Nitrous Express wet nitrous kit, | Centerline Telstar 15x4 |
150hp shot, Dynotune nitrous- | Tires |
bottle heater, {{{NX}}} purge, MSD | 165R15 |
rpm digital window switch | Rear Suspension |
Fuel System | Springs |
SVT Focus fuel pump, FRPP 30-lb/hr | Eibach Sportlines |
injectors, stock lines and rails | Shocks |
Exhaust | Tokico Illumina five-way adjustable |
Flowtech ceramic-coated long- | Control Arms |
tube headers with matching | Stock |
X-shape crossover, Flowmaster | Brakes |
two-chamber mufflers | Stock |
Transmission | Wheels |
Stock 3650, stock clutch, stock | Centerline Telstar 15x8 |
shifter with short handle | Tires |
Rearend | Mickey Thompson E/T Street |
8.8, FRPP 3.73 gears | Chassis Stiffening |
  | Maximum Motorsports full- |
ELECTRONICS | length subframe connectors |
Computer |   |
Stock, SCT XCalibrator-tuned |   |
