Michael Johnson
January 4, 2007
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block
Stock 5.0
Displacement
302 ci
Rotating Assembly
Stock 5.0
Cams
Stock
Heads
Edelbrock Performer, Crane Cobra 1.7-ratio roller rockers
IntakeFRPP Cobra
Throttle Body
Professional Products 70mm
Mass Air
Lightning 90mm
Power Adder
ProCharger P-1SC supercharger and intercooler
Fuel System
BBK 255-lph fuel pump, stock fuel lines and rails, FRPP 42-lb/hr injectors
Exhaust
MAC 151/48-in, equal-length, short-tube headers, Bassani X-style crossover pipe, Flowmaster after-cat
Transmission
Stock T5, FRPP heavy-duty clutch, Steeda Tri-Ax shifter
Driveshaft
FRPP aluminum
Rearend
8.8, FRPP Traction-Lok, 3.55 gears
ELECTRONICS
Engine Management
Stock computer, SCT tuned by Kennedy's Dynotune
Ignition
MSD 6AL, FRPP spark-plug wires
Gauges
Stock
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-member
Stock
Control arms
Stock
Springs
BBK
Struts
Tokico Illumina five-way adjustable
Caster/Camber
Hotchkis
Brakes
FRPP M-2300 brake kit with 10th Anniversary Cobra calipers, cross-drilled rotors
Wheels
Bullitt 17-in
Tires
Goodyear Gatorback ZR45 245/45-17
REAR SUSPENSION
Springs
BBK
Shocks
Control arms
BBK tubular upper and lower
Brakes
Wheels
Bullitt 17-in
Tires
Chassis Stiffening
Kenny Brown Performance Double-Cross subframe connectors and g-Load brace
