K.J. Jones
February 7, 2006
Photos By: Steve Turner
How stock is "stock"? This Cobra's mill still uses every piece of internal equipment that Ford gave it, from crankshaft to valves. DynoSpeed Racing added a Sullivan Performance intake manifold and fuel rails, 60-lb/hr fuel injectors, an Accufab throttle body, an SCT BA2800 mass air meter, dual fuel pumps courtesy of a Lincoln Aviator, NGK plugs, an HP Performance Twin-Turbo Kit that includes 57mm Garrett turbos (HP's '03-'04 Cobra kit comes with 50mm Garretts; the 57mm turbos are a $500 upgrade), and HP's air-to-air intercooler. DynoSpeed dials in the engine's tune-up with an SCT XCalibrator. The setup cranked more than 811 hp to the rear wheels of Mike's ride, and 717 lb-ft of torque. At the dragstrip, Mike has pushed the turbocharged/stick-tranny combo to a best e.t. of 9.90 at 143 mph.
5.0 Tech specs
ENGINE AND DRIVETRAINIgnition
BlockStock EEC V
StockGauges
DisplacementAEM air/fuel, Lunar (boost), Raptor
Stock shift light
Cylinder Heads
Stock SUSPENSION AND CHASSIS
CamshaftFront Suspension
StockK-member
Intake ManifoldQA1
Sullivan PerformanceA-arms
Throttle BodyQA1
Accufab OvalSprings
Mass Air MeterQA-1
SCT BA 2800Struts
Air FilterLakewood
Twin HP Performance conicalWheels
Power Adder15-in Weld AlumaStar 2.0
HP Performance '03-'04 Twin-TurboTires
Kit, featuring 57mm GarrettMickey Thompson
turbochargers and air-to-air intercoolerBrakes
ExhaustStock
HP Performance turbo headersRear Suspension
and Borla mufflers w/ 3-in tipsSprings
Fuel SystemStock
Twin {{{Lincoln}}} {{{Aviator}}} fuel pumps,Shocks
Sullivan fuel rails, 60-lb/hr injectors,Strange
Aeromotive filter, Ford returnlessTraction Devices
fuel-pressure sensorNone
TransmissionWheels
Six-speed T56 transmission w/15-in Weld AlumaStar 2.0
G-Force gearsetTires
RearendHoosier Quick Time Pro 28x11.5-in
Stock Ford 8.8 live-axle rear w/Brakes
3.55 gears, Strange axlesStock
 Chassis Stiffening
ELECTRONICSSteeda subframe connector
Engine Management
SCT Xcalibrator
