Michael Johnson
July 1, 2005
Photos By: Steve Turner
Since all the power improvements have centered on support equipment for an ATI-ProCharger P-1SC supercharger, the Mach 1's Four-Valve cam covers haven't budged. As is usually the case, the P-1SC included a three-core intercooler, but Athena's Mach also boasts Ford Racing Performance Parts 42-lb/hr injectors, an ATI-supplied computer chip, NGK TR6 spark plugs, and a complete Bassani exhaust system. To get the power to the pavement, Athena's Mach utilizes a Clutch Masters clutch, an Eaton differential, Strange 31-spline axles and 4.10 gears, and a Steeda Tri-Ax shifter.
ENGINE AND DRIVETRAINGauges
BlockAuto Meter boost and fuel pressure
Stock Mach 1
Rotating AssemblySUSPENSION AND CHASSIS
Stock Mach 1Front Suspension
DisplacementK-member
281Stock
CamshaftsControl Arms
Stock Mach 1Stock
Cylinder HeadsSprings
Stock Mach 1Stock
Intake ManifoldStruts
Stock Mach 1Stock
Throttle BodyCaster/Camber
Stock Mach 1Stock
Power AdderWheels
ATI-ProCharger P-1SCWeld Racing Rodlite XP 18x9
supercharger with three-coreTires
intercooler, 4-in pulleyFalken 245/40
ExhaustBrakes
Bassani Mid-Length headers,Stock
high-flow X-pipe, and after-catRear Suspension
Fuel SystemSprings
Stock fuel pump, lines, and rails;Stock
FRPP 42-lb/hr injectorsShocks
TransmissionStock
Stock 3650, Clutch MastersTraction Devices
clutch, Steeda Tri-Ax shifterHP Motorsports upper and lower
Rearendcontrol arms
8.8, Eaton differential, Strange 4.10Wheels
gears and 31-spline axlesWeld Racing Rodlite XP 18x9
 Tires
ELECTRONICSFalken 265/35
Engine ManagementBrakes
Stock Computer, ATI-ProChargerStock
performance chipChassis Stiffening
IgnitionHP Motorsports subframe
Stock, NGK TR6 spark plugsconnectors and driveshaft loop
