Dr.Jamie Meyer
March 1, 2005
Will Zack and Steve continue their run in NMRA SSO? It looks as if the '04 season belongs to Jim Blair, but things could be different in 2005. Jim will grad-uate up to the looming NMRA 10.5W-tire class, and SSO will be wide open again. The Posey family could well inherit the throne if its Sonic Blue monster continues to progress in its development as a small-tired race car.
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block FRPP aluminum (9.5-in deck)
Displacement 410 (4.125-in bore x 3.{{{850}}}-in stroke)
Cylinder Heads Brodix BF202 ported by {{{Fox}}} Lake
Camshaft Cam Motion custom solid-roller
Intake Manifold Ported FRPP X351
Throttle Body 105mm Wilson Manifolds
Power Adder ATI-ProCharger F-3R
Exhaust Paul’s Automotive Engineering custom headers, DynoMax Bullet mufflers
Fuel System MagnaFlow pump, Aeroquip line, 160-lb/hr injectors, MagnaFlow fuel-pressure regulator
Transmission Dynamic Powerglide w/TCT torque converter
Rearend PA Racing Fab-9, Strange spool, Strange 40-spline, gun-drilled axles, 3.60:1 gears
ELECTRONICS
Engine Management FAST, tuned by Mike Wilson of Paul’s Automotive Engineering
Ignition MSD 10; MSD 8.5mm wires; NGK spark plugs
Gauges Auto Meter
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-Member AJE
A-Arms PA Racing
Springs AFCO
Struts Santhuff
Wheels Bogart
Tires Mickey Thompson 26x4.5
Brakes Strange
REAR SUSPENSION
Springs AFCO
Shocks AFCO double-adjustable
Traction Devices PA Racing ladder-bar rear suspension
Wheels Bogart
Tires Mickey Thompson 28x10.5
Brakes Strange
Chassis Stiffening 25.2 SFI-certified chassis by Paul’s Automotive Engineering
