December 1, 2004
We first met Tim Stockwell in the pages of 5.0 Mustang & Super Fords magazine during our evaluation of the Snow Performance methanol-injection kit ("Cool Your Jets," Nov. '04, p. 100). So, you may have some idea of what this car is all about. But the car isn't the only story here. As with most labors of love, the man behind the project is the real story. Tim, who is retired at the ripe old age of 37, has been building and racing cars since he was 19. His specialty is pushing stock-component cars beyond their perceived capabilities.
Whether you want to admit it or not, a "stock" car is just about the coolest thing you can build. How limited is Tim's creation? In a nutshell, this car has only a blower, a drag suspension, and one sweet tune. Now, that could be the end of the story right there. You could just go ahead and look at the pictures and read the captions. But, as we said, this is more about how Tim has pushed a largely stock 5.0 Mustang beyond anything you have ever imagined.
Tim has owned more 5.0s than the average enthusiast-more, in fact, than most used-car lots. As his cars have come and gone, he has slowly refined what combinations he likes and those collection of parts that he'd rather forget. With all that quality time spent learning the intricacies of the Mustang, Tim realized that the more stock the car (while still being fast), the better he liked the total package.
The one thing Tim's friends know about him is, regardless of the combination, his cars are impeccably prepared. Just look at this one-flawless from top to bottom. We doubt Tim is done moving 5.0s, but this car has already earned a special spot in his heart.
"The car was a California car its entire life," he says. "I bought it in January 2004, completely stock. I wanted a simple, basic, street car, so I removed the A/C, made a firewall delete plate, reworked the heater controls to remove the A/C markings, installed a Flaming River manual rack and shaft, and hid the entire fender wiring inside the inner fenders. Basically, I tried to declutter the engine bay as much as possible without removing the engine. I wanted to maximize the stock engine's potential before it comes out for internal mods. Since most people change the heads, cam, and intake right away, I wanted to see what it could do all stock internally-back to my old Buick days! My goal is simply to go as fast as I can, as inexpensively as possible, without making things any more difficult than they need to be."
Has Tim met those goals? We'll let you be the judge. We'd say the car is an unbelievable example of what the 5.0 Mustang hobby is all about-choose your path, stick to it, and be rewarded with a special car. The other huge advantage to owning/building a stocker is the price. Tim got the completely stock '92 LX coupe with 39,000 miles for $5,500. After he sold the A/C, the P/S, the Pony rims, and the factory-fresh exhaust, he had only $3,300 in the car. He estimates that even with all the performance parts he added (the $2,500 S-Trim kit being the biggest hit), he's into this 10-second car for only $8,000. Find a cheaper way to go 10s and we'll buy it!
Tim ran an 11.64 at 116.25 mph before the Snow Performance methanol injection system went on. On that 11.60 pass, the car still had the stock 3.27 gears and stock H-pipe. Then, with the tuning that we outlined in the tech story, the white coupe blasted off an 11.330 at 119.14 mph. That came with a 60-mile round trip to the track on drag radials with 94-octane Sunoco in the tank.
As this story went to press, Tim did the impossible. He-well-pressed his luck with that stock combination even more. He installed the larger Snow Performance methanol nozzle, maxed out the methanol system's pump (140 psi), upped the methanol mix/water mix to a 65:35 blend, set the base timing at 12 degrees initial, and installed a 2.75-inch Vortech supercharger pulley for a 17-psi max boost shot at the gold. Pressed for time at the track, Tim still managed a jaw-dropping 10.91 at more than 123 mph. Oh, and we have the timeslip from Tim to prove the run is legit.
You've read about some crazy stuff in these pages before, but did you ever think a 5.0 Mustang could go this fast with so much stock stuff remaining-and be street and emissions legal? Using what the factory has provided us with has been the heart and soul of this hobby since 1987. But Tim has taken that philosophy to a whole new level. Let the bench racing begin.
Tim Stockwell: The Buick Years
Tim is no stranger to extreme, stock-component street cars. In 1996, he outdid himself with one of his other favorite cars-the '86-'87 turbocharged V-6 Buick. Tim took a white-with-chrome '87 Turbo-T all the way to the 10-second zone with a stock, never-opened motor, converter, transmission, and rearend.He did add a larger turbo and a more efficient intercooler, fuel system, and drag suspension, but the vast majority of the car remained pain-fully stock. With the boost cranked well past the 30-psi level, Tim went as fast as 10.76 at 123.43 mph (1.45 60-foot times)-enough to have the rest of the Buick universe crying foul. After a complete teardown of that car, Tim was found legit, and his record-setting Buick legacy lives on to this day.
Block Stock
Displacement 302 ci
Cylinder Heads Stock
Camshaft Stock
Intake Manifold Stock
Throttle Body Stock
Power Adder Vortech V-1 S-Trim
Exhaust BBK 15¼8-in, short-tube headers;
BBK H-pipe; Flowmaster two-chamber
mufflers; Flowmaster stainless tips
Fuel System Walbro GSS 342-lph fuel pump (in tank); 42-lb/hr injectors; Kirban
adjustable fuel-pressure regulator
Transmission Stock AOD (never opened); Precision Industries 9.5-in converter
w/4,000 stall
Rearend Stock 8.8 w/3.73 gears
Engine Management Stock A9P computer
Ignition MSD 6AL, SS coil, two-step, and Vortech boost retard
Gauges VDO boost gauge w/an Auto Meter shift light
K-Member Stock
A-Arms Stock
Springs Four-cylinder {{{Mustang}}}
Struts Lakewood {{{90}}}/10
Wheels Weld Draglite 15x4 (211/44-in backspacing)
Tires Kumho 165/{{{80}}}/R15
Brakes Stock
Springs Stock 5.0 w/one coil removed
Shocks Lakewood 50/50
Control Arms KSR lowers, Maximum
Motorsports double adjustable uppers
set at 4-deg pinion angle
Traction Devices Airbag in right rear coil
Wheels Weld Draglite 15x8 (511/42-in backspacing)
Tires BFG 275/60/15
Brakes Stock
Chassis Stiffening Steeda full-length subframes welded in
