Michael Johnson
November 1, 2004
Once tuned up and looking good, it was off to the dyno, where, on the 100-horse jetting, the GT is good for 372 hp and 436 lb-ft of torque at the rear wheels. It's also good enough for 11.90s on Nitto drag radials in complete street trim. Bob says his present goal is to run 11.60s at more than 120 mph with the larger 150hp jets in the NOS system. He's also thinking about adding a Vortech or a Pro Turbo Kits single turbo kit utilizing whatever money he can make from side jobs out of his garage. Wait a minute, Bob. Isn't this where it all began in the first place? Guess we'll see you in the 10-second zone next year.
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block Stock (91,000 miles)
Displacement 302
Cylinder Heads Edelbrock 60379
  aluminum (Performer 5.0)
Camshaft Anderson {{{Ford}}} Motorsport B-21
Intake Manifold Cobra intake,
  Extrude Honed
Throttle Body BBK 65mm
Mass Air Pro-{{{M}}} 80mm
Intake Morpheus Performance
  Horsepower Pipe
Power Adder NOS “dry” 75-175hp shot
Exhaust MAC 15¼8-in equal-length
short-tube headers, Bassani catalytic
X-pipe, MAC Flowpath mufflers
w/2.5-in MAC chrome exhaust tips
Fuel System Walbro 255-lb/hr
in-tank pump, 30-lb/hr Ford injectors,
Aeromotive fuel-pressure regulator
Transmission ’95 Cobra T5
  five-speed
Rearend 8.8 w/3.73 Ford
Racing Performance Parts gears, stock
28-spline centersection with repacked clutches
ELECTRONICS
Engine Management PMS
Ignition MSD 6AL ignition, MSD billet
  distributor, Autolite plugs
Gauges Factory
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-Member Stock
A-Arms FRPP
Springs Steeda Sport
Struts Tokico nonadjustable
Wheels 17x9 Wheel Replica Chrome Bullitt
Tires Hankook 255/40/17
Brakes Stock GT w/Bendix pads
REAR SUSPENSION
Shocks Tokico nonadjustable
Traction Devices X2C Boxer ST upper and lower control arms, Energy suspension
  bushings, ’98 Cobra rear sway bar,
  trimmed pinion snubber
Wheels 17x10.5 Wheel Replica
  Chrome Bullitt
Tires Nitto Drag Radials (315/35/17)
Chassis Stiffening N/A
