Michael Johnson
Technical Editor
September 1, 2004
Photos By: Stever Turner
The NMRA's EFI Renegade class has had its fair share of big-name racers-Chip Havemann, Bob Kurgan, Jimmy LaRocca, Bart Tobener, Mike Post, and Brian Meyer immediately come to mind. But with Kurt Gallant's '03 championship run and successful start to the '04 season, we need to add his name to that list.
Kurt made himself the man to beat in EFI Renegade, and he's done it with a power adder that few in the class run-i.e., nitrous, the jug, the bottle, the squeeze, or whatever you call it. Tim Lyons showed a nitrous car could be competitive in EFI Renegade; Kurt took up where Tim left off, and he shows no signs of slowing down anytime soon.
It might seem that Kurt came out of nowhere to dominate EFI Renegade, and that statement is mostly true. He built the car in 1995 with Ron Sharp at Advanced Airflow Engineering in Clinton Township, Michigan. At that time, it had a naturally aspirated engine. Kurt ran the car in local test-and-tune and street race-type stuff.
EFI Renegade racers can thank past NMRA Super Street Outlaw racer Jeff Tyson for getting Kurt into the NMRA. Kurt knew Jeff because both utilized the services of Ron Sharp. Kurt's first NMRA experience came at the '01 World Finals in Bowling Green, Kentucky. He was still running a naturally aspirated engine. In the Hot Street class, the car ran in the 9.60s, which at that time was competitive. With his appetite for NMRA racing in full-slobber mode, Kurt's intention was to build the car into an all-out Hot Street racer. But somewhere along the line, the car ended up with a Nitrous Express system on it, and the rest is EFI Renegade history.
In 2002, Kurt qualified well, but going rounds was a problem as he tested the durability of mechanical components. As have many other racers before him, Kurt acknowledges his first year was a learning period and an opportunity to test different ideas. "We tested and tuned till our eyeballs came out," he says of the '02 season. By 2003, however, he and Ron had the combo sorted out and ready to go. "We took what we learned in 2002 and applied it to the '03 racing season."
Boy, did they apply it well. In EFI Renegade-one of the more closely competitive NMRA classes-Kurt came out running and won Bradenton, followed by wins at Joliet, Illinois; Ennis, Texas; and Atco, New Jersey. For his efforts, he was crowned EFI Renegade champ for garnering 3,225 points, almost 1,000 points more than the Second-Place, Bob Kurgan. For 2004, Kurt picked up where he left off by winning the first two races at Bradenton, Florida, and Reynolds, Georgia.
At the third stop on this year's NMRA tour-National Trail Raceway in Columbus-the weather wreaked havoc on Kurt's nitrous tune-up, and the suspension was a little out of whack. The first round of qualifying resulted in a lousy 60-foot time, but the car still ran in the 8s. The suspension was dialed in for the second round of qualifying, and the car responded by running its best time in NMRA trim with an 8.73 at 155mph. "We thought we had it, but we didn't," Kurt says, referring to the tune-up.
Kurt made a half-track pass in his first-round bye run, but the tune-up was way off, resulting in a couple wounded pistons. "We didn't have enough fuel in the car," he says. "The nitrous setup is very, very touchy in the cold weather." For that reason, and the fact that warm weather is not ideal for the blower cars, Kurt likes it hot. "Hopefully, it's 95 degrees every race," he says.
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block FRPP R302
Displacement 358 ci
Rotating Assembly Scat billet crank, GRP
aluminum rods, Diamond pistons
Cylinder Heads Canfield aluminum heads,
Advanced Airflow Engineering-ported, T&D
Machine shaft rockers, Del West titanium valves, Diamond Racing valvesprings
Camshaft Comp Cams
Intake Manifold Edelbrock Victor 5.0
Throttle Body Accufab 75mm
Mass Air Pro-{{{M}}} 80mm, Mike Naber-custom air intake
Power Adder Nitrous {{{Express}}} SX2 Dual-Stage fogger, single 15-pound bottle, purge, bottle heater
Exhaust Mike Naber-custom long-tube stepped header, DynoMax Bullet mufflers
Fuel System Weldon 2025 and 2035 pumps, Earl's braided fuel lines,
Mallory fuel rails, MSD injectors, Weldon fuel-pressure regulator
Transmission Dynamic Mighty-Mite 2 C4, TCT converter,
Cheetah SCS Turbo Action shifter,
Dynotech aluminum driveshaft
Rearend {{{DTS}}} 9-in, Moser 35-spline axles, Strange centersection setup by
Walsh Motorsports, Skinny Kid
Race Cars-strengthened
ELECTRONICS
Engine Management Stock EEC IV, Autologic chip, Alternative Auto-tuned
Ignition MSD Digital 7, MSD HVC 2 coil, Moroso plug wires, NGK plugs
Gauges Auto Meter
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-Member AJE tubular
A-Arms AJE tubular
Springs Koni coilover
Struts Koni adjustable
Wheels Weld Pro Stars
Tires Mickey Thompson Front Runners
Brakes Aerospace Components
REAR SUSPENSION
Springs Stock {{{Mustang}}} {{{GT}}}
Shocks Santhuff double-adjustable
Traction Devices Wolfe Race Craft upper and lowers and antiroll bar,
Energy Suspension bushings, tuned by
Jeff Tyson at Tyson Automotive
Wheels Weld Pro Stars 15x10
Tires Mickey Thompson E/T Drag
Chassis Stiffening Reiter's Metalcraft 12-point Funny Car cage and
through-the-floor subframe connectors
