Steve Turner
September 1, 2004
Photos By: Courtesy of Anderson Ford Motorsport
Longtime readers may remember we covered Rick Anderson's pursuit of high-revving, naturally aspirated horsepower in our Oct. '02 issue ("Natural High," p. 55). Back then Rick had D.S.S. put together a ready-to-rev 347 with lightweight parts inside a Ford Racing Performance Parts Sportsman block. The package worked well, churning out more than 450 hp and revving well past 8,000 rpm! Combining the torque of a 347 with the rev-happy nature of a 4.6 Cobra, this engine has long been on our list of engine combinations to put in a car.
Of course, too much is always just about right, so we also wondered how such a combination might accept a bit of nitrous. Well, it seems Rick has been wondering too, especially with all those NMRA Real Street and Renegade racers flying on the sauce. He also saw it as an opportunity to utilize the flexibility of his favored Programmable Management System. He reasoned that dry nitrous systems are great for the street because you needn't muss with extra fuel lines and such, and there's a reduced chance for intake backfires. All you'd need is an appropriately sized set of injectors and a PMS to tune it all up.
From that thought process, Rick decided to develop some nitrous packages built around the concept of dry nitrous controlled and tuned by the PMS. The kit installed and tested here is the heavy hammer-an NOS direct-port good for 750 hp at the rear wheels. There are also several smaller single- and dual-nozzle systems available. These kits are less expensive and easier to install, but they don't offer the ultimate power potential and even distribution of the direct-port system.
As it turns out, once you install the kit, the tuning is actually quite easy. Rick will help you choose the right injectors and give you a base tune-up for the PMS. From there, it's just big power at the touch of a button.
RICK ANDERSON'S COUPE
ENGINE AND DRIVETRAIN
Block FRPP Sportsman
Cylinder Heads Trick Flow Twisted Wedge (AFM Stage V porting)
Intake Manifold Vortech Mondo Box upper
Camshaft AFM S25810
Power Adder 360hp AFM/NOS kit
Exhaust Bassani 13¼4-17¼8-in
stepped long-tube headers, Bassani 3-in X-pipe
Fuel Pump Aeromotive A1000
Fuel Injectors 55-lb/hr injectors
Transmission TTC-Tremec T5 (prepped by Pro Motion w/G-Force gearset)
Rearend 8.8 w/4.56 gears
ELECTRONICS
Engine Management EEC IV
w/Programmable Management System
Ignition Mallory Hy-Fire VIIS
w/ProMaster coil
Gauges Auto Meter
SUSPENSION AND CHASSIS
Springs FRPP drag
Struts/Shocks AVO
Rear Suspension HP Motorsports
upper control arms, HPM Mega-Bite lower control arms, and HPM antiroll bar
Wheels Weld Aluma Star
Tires Akurer (front), Mickey Thompson (rear)
Brakes Wilwood discs (front), stock rear
