Dale Amy
August 1, 2004
Photos By: John Roper
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block Stock 5.0 roller
Bore 4.030
Stroke 3.40
Displacement 347 ci
Crank {{{Eagle}}} 4340 forged steel
Rods Eagle “ESP” 4340 H-beam
Pistons SRP forged, 10.0:1
Cam Trick Flow Stage 2
Heads Trick Flow Twisted Wedge
Intake Holley SysteMAX II (polished)
Mass Air Pro-{{{M}}} 75mm Bullet
Throttle Body Accufab 70mm (polished)
Cold Air MAC (polished)
Fuel Pump 255-lph Walbro in-tank
Regulator Aeromotive billet adjustable
Exhaust MAC short-tube headers,
Bassani X-pipe, DynoMax high-flow cats,
Flowmaster two-chamber mufflers
Transmission T5, with Tri-Ax shifter
Clutch Centerforce Dual Friction
Rearend 8.8 w/3.73 gears
ELECTRONICS
Engine Management EEC IV, w/TwEECer
Ignition Stock, w/MSD distributor
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-Member Stock
Control Arms Stock
Springs Edelbrock
Struts Edelbrock
Brakes ’93 Cobra R,13-in
Wheels Cobra R, 17x9
Tires Nitto
REAR SUSPENSION
Shocks Edelbrock
Springs Edelbrock
Brakes '93 Cobra R, 11.65-in
Tires Nitto Drag Radial
Subframes Kenny Brown, w/jacking rails
