Dale Amy
August 1, 2004
Cobra owners are a justifiably proud bunch, happy to cough up the hefty premium that snake ownership demands, knowing they're getting something special and exclusive in return. They make this fiscal sacrifice-leaving bags of extra cash with the dealership and perhaps their first-born child with the insurance company-for a number of reasons. Certainly not the least of these reasons is the soul-satisfying knowledge that the Four-Valve cammer has invariably made the Cobra the most powerful modular Mustang in any given model year.
You may recall, however, that the golden-horsepower rule came close to being broken in 1999. That was the year the modular GT finally grew a pair, while at the same time the Cobra suffered partial emasculation when its factory 320hp rating was found to be more than a bit optimistic-the apparent victim of some intake, exhaust, and calibration blunders.
Of course, computer-whiz Benjamin Lee had no way of knowing that when-as a birthday present to himself-he picked up this spanking-new Cobra in November 1999, telling his wife, Debra, it would be their "Sunday afternoon car." He says he didn't mention she wouldn't be able to drive it after the modifications.
Those mods began within days of the purchase, with Flowmasters and an X-pipe changing its aural attitude. When word got out about the power deficiency, Ford invited the Cobra back to the dealership for a fix that added about 10 hp-a step in the right direction, but still not enough for Ben. As owner of the firm Computer Integration, Ben had plenty of online time to scope out the Internet, researching what his next step should be. This resulted in the purchase of a ProCharger P-1SC. Ben thought the P-1SC, with its intercooler, would be ideal for a daily driver and that it would allow dialing up the boost a bit. Apparently he was a little too nervy with the boost dialing and promptly laid waste to his unsuspecting modular's stock bottom end.
That's what brought Ben to No Limit Motorsports [(404) 366-3037] in Forest Park, Georgia, where owner Mike Johnson set about building a new long-block that would be up to the task. Regular readers may recall that it was Mr. Johnson who was responsible for Aaron Archer's eight-second modular racer featured on our September '03 cover. The full details of the new cammer's construction can be scoped in our 5.0 Tech Specs sidebar, but the basics include Manley billet rods, CP pistons, and a stock Cobra crank, all housed within a '98-style Cobra alloy block bored 0.020 inch over. No Limit then ported a set of Four-Valve heads and fitted them with a set of the company's own camshafts.
According to Mike, No Limit is a shop that basically does "everything but paint." The company constructed the car's six-point cage with a Pro-Stock- style rear hoop, and ditched the IRS in favor of an 8.8-inch stick axle fortified with 31-spline Superior axles, 4.30 gears, and an Auburn Pro diff. While the rest of the fairly extensive list of chassis mods is also listed in the spec box, it's important to remember that this is not some quarter-mile warrior; it's Ben's street car-one now boosted by no less than a ProCharger F-1R that previously saw battle on Aaron Archer's race car. This may explain why-at somewhere between 12 and 15 psi of boost-the black beauty now possesses more than 700 rwhp and 596 lb-ft of torque on pump gas.
Wait, there's more. Ben purchased Aaron's used F-2M blower, along with a cog-drive system. This has yet to be installed as we write, but Mike envisions no problems tuning it for perfect street manners with the FAST fuel-injection system that he used to make the F-1R so civilized (all conveniences, including A/C, are still functional-this is Georgia, after all). We can't tell you what the car runs in the quarter-mile because the strip is not high on Ben's priority list, but, as mentioned, Aaron's similar setup is good for mid-eights. We say this just in case you were thinking all '99 Cobras are easy pickings. Ben and Mike have compensated nicely for this one's factory shortcomings.
Block Stock ’98 Cobra
Bore 3.572
Stroke 3.5433 (stock)
Displacement 284 ci
Crank Stock Cobra
Rods Manley billet
Pistons CP
Cams Custom No Limit Motorsports
Heads Ported by No Limit Motorsports
Intake Stock, ported by
Throttle Body Accufab 90mm
Injectors 96 lb/hr
Fuel Pump Aeromotive
Headers MAC long-tube
Exhaust Custom X-pipe,
w/Flowmasters and stock tailpipes
Power Adder ProCharger F-1R (to be replaced by cog-driven F-2M)
Transmission Tremec T56 six-speed,
w/SPEC Stage III clutch
Rearend 8.8 live axle, Superior
31-spline axles, 4.30 gears, Auburn Pro
Cage Custom No Limit Motorsports
Subframes Kenny Brown
Engine Management FAST, tuned by
Ignition MSD
Gauges Auto Meter
K-Member D&D Motorsports
Control Arms D&D Motorsports
Springs/Struts Koni coilover
Brakes Power Slot rotors and Hawk pads
Wheels Mille Miglia 19x9.5
Tires Michelin 245/35x19
Springs/Shocks Tokico/Sport Line
Control Arms Steeda upper and lower
Wheels Mille Miglia 19x10.5
Tires Michelin 285/35x19
