March 1, 2004
5.0 TECH SPECS
ENGINE AND DRIVETRAIN
Block Lightning 351 roller
Displacement 408
Cylinder Heads Brodix Track 1, M2-S
Camshaft Custom Comp Cams hydraulic roller w/0.565-in lift
Intake Manifold Edelbrock Victor EFI
Throttle Body Accufab 75 mm
Power Adder N/A
Exhaust MAC 13¼4-in long-tubes, Dr. Gas X-pipe, Flowmaster mufflers
Fuel System Aeromotive w/38-lb/hr injectors
Transmission Tremec five-speed
Rearend 8.8, 33-spline Moser axles, Eaton posi, 3.73 gears
ELECTRONICS
Engine Management Stock computer w/Mike Murillo-tuned Autologic chip
Ignition MSD 6AL w/FRPP wires
Gauges Yes
SUSPENSION AND CHASSIS
Front Suspension
K-Member D&D tubular
Springs D&D coilover
Struts Lakewood 70/30
Wheels Weld Draglite
Tires Skinnies
Brakes Stock
Rear Suspension
Traction Devices Steeda upper and lower control arms
Springs MAC
Shocks KYB
Wheels Weld Draglites
Tires 26x10 Mickey Thompson
Brakes Stock
Chassis Stiffening Subframe connectors
