Michael Johnson
December 1, 2003
ELECTRONICS
Engine Management Stock computer, Auto Logic/Kauffman Motorsports chip
Ignition Stock, FRPP plug wires, NGK TR6 plugs
Gauges Stock, Auto Meter
SUSPENSION AND CHASSIS
FRONT SUSPENSION
K-Member D&D Performance tubular
Caster/Camber D&D Performance
Struts Tokico Illumina five-way adjustable
Springs Kenny Brown
Brakes Stock, Hawk pads
Wheels OE Concepts Chrome Bullitt (street), Weld Draglites (track)
Tires Nitto NT555 (street), Futura skinnies (track)
REAR SUSPENSION
Traction Device UPR upper and lower control arms
Shocks QA1 adjustable
Springs Kenny Brown
Brakes Brembo rotors, Hawk pads
Tires Nitto NT555 (street), Mickey Thompson ET Drag (track)
Chassis Stiffening Maximum Motorsports subframe connectors, Rhodes Custom Auto rollcage
5.0 TECH SPECS
JOSEPH ANE MARION BAUER'S '96 COBRA
ENGINE AND DRIVETRAIN
Block Stock aluminum Cobra 4.6
Cylinder Heads Stock aluminum Cobra Four-Valve
Intake Manifold Stock Cobra
Throttle Body Stock Cobra
Mass Air Pro-M 80mm, AFM Power Pipe, K&N filter
Exhaust JBA headers, Bassani X-pipe, Flowmaster two-chamber mufflers, stock tailpipes
Fuel Pump Walbro 255-lph
Injectors Stock
Transmission T45 by Scott Lehr, McLeod Kevlar disc, FRPP pressure plate, FRPP aluminum driveshaft, Steeda Tri-Ax shifter
Rearend 8.8, Ford Truck differential, Superior 31-spline axles, 4.30 gears
ELECTRONICS
Engine Management Stock Cobra, Autologic/Kauffman Motorsports chip
Ignition Stock Cobra, FRPP 9mm plug wires, NGK TR6 plugs
Gauges Stock
FRONT SUSPENSION
K-Member Stock
Struts QA1 adjustable
Springs FRPP B springs
Brakes Stock Cobra rotors, stainless steel lines, Hawk pads
Wheels Azev Type-A 17x7.5
Tires BFGoodrich g-Force KDW 245/40
REAR SUSPENSION
Traction Device UPR double-adjustable upper control arms, Maximum Motorsports adjustable lower control arms
Brakes Stock Cobra, Hawk pads
Wheels Azev Type-A 17x10
Tires BFGoodrich g-Force KDW 275/40
Chassis Stiffening Steeda subframe connectors, Rhodes Custom Auto Works rollcage
