November 1, 2003
I got your bling-bling right here, buddy! Scott has gone to great lengths to make this an engine compartment that car-show judges just have to stop and admire. Once you get past the optical assault, you'll find the handiwork of hard-core speed freaks. Steeda installed the Vortech S-Trim with a 3.33-inch blower pulley (12 psi). Mike Wilson at Paul's Automotive Engineering finished off the deal with 42-lb/hr Ford Racing Performance Parts fuel injectors, an MSD ignition, and a custom tune on Paul Faessler's chassis dyno. The intake is further enhanced by a Pro-M 87mm mass air meter, an Anderson Power Pipe, and an aluminum discharge tube. The whole deal adds up to the typical 470-plus-rear-wheel-horsepower, Vortech-blown, 4.6 Four-Valve, Ford small-block (or "Vobra" as it's known in Internet chat rooms).
Horse Sense: In the past couple years, one of the hottest trends in the Mustang world has been the adornment of the interior and engine compartment with billet-aluminum aftermarket replacement pieces. At $25-$150 for the average add-on, these pieces are affordable eye candy for the owner, passenger, or car-show judge.
When do you stop? When have you added enough power, tweaked the suspension just right, and massaged the look to the point that it halts traffic? Those are the questions that face the top Mustang builders in the hobby. Now, if you're assembling a Mustang to dominate a heads-up class, some of those questions can be answered by how you stack up against your closest competition. But if you're building a show car, how do you know when you've crossed the line from perfect street stomper to overblown nut job? Yes, things can be tough on the car-show circuit, but when you get it just right, your success can be measured in trophies won and smiles granted to the onlookers.
The Mustang super-enthusiast whose handiwork you see here is Scott List, a 48-year-old electrical distributor from Greenville, Ohio. He took delivery of his delicious '98 Cobra on Valentine's Day of that year, and it's been a labor of love ever since.
"When I started out," Scott says with youthful enthusiasm, "I knew I was going to modify." His goal was to have "a car that looked darn good and ran better!" And so the modifying began with some of the premier shops in the aftermarket industry.
His first stop was at Steeda, which did the Vortech blower and a complete race-inspired, G-Trac suspension. A Steeda heavy-duty radiator and 3.73 gears were added to make sure everything worked well together. A year later, Scott and his wife, Cheryl, were back for brake upgrades and the R hood. After a string of T45 failures, Sean Hyland Motorsport installed the bulletproof Tremec T56 trans in September 1999-it's held together ever since.
After some success on the car-show circuit, Scott became interested in open-track events. He took driver training courses at Gingerman Raceway in Michigan and Track Days at Road Atlanta. He plans to ultimately enter the car in the hot NASA American Iron series that's sweeping the nation. This means all those beautiful add-ons may be placed back in their boxes as Scott looks to pare weight from the Cobra for competition's sake.
So, it looks as if even Scott has found his limit. As the car sits, it's a show car, a road rocket, or whatever he wants to make of it. It's extreme enough to win trophies but also competitive enough to set lap times. Along the way, the Cobra has helped Scott become addicted to the road-course way of life. The next time you see this car, it will probably still have the attention-getting goodies on it, but maybe with just a little more serious underpinnings. Regardless, Scott has assembled a classic example of how Mustangs can continue to evolve no matter how much you put into them. After all, when is too much of a good thing really too much?
You can tell there's been a lot of time spent on the interior. There are Auto Meter gauges, an A-pillar pod, a carbon-fiber dash kit, an FR500 steering wheel, and more billet add-ons and doodads than you can shake a snake at! However, this Cobra becomes more "race car" every year, and that's just how Scott likes it. Tom Honsaker from Paul's Automotive Engineering installed the Kenny Brown cage, the Simpson five-point harnesses, and the Maximum Motorsports' full-length subframe connectors. The Steeda Tri-Ax shifter is attached to an SHM-prepared T56 six-speed box-the only thing Scott has found that will stand up to the extra grunt of the blown four-cammer. A King Cobra clutch clamps the power from the billet steel flywheel. The aluminum FRPP driveshaft sends the power to a stock rearend that houses 3.73 gears.
These gorgeous MOMO rims dominate the exterior of the Cobra. Wrapped in Toyo rubber, the wheels measure 18x8.5 up front and 18x10 in the rear. The stock '98 Cobra coupe body has also been augmented with a Steeda "R" fiberglass hood and Steeda wing. Scott Winger is responsible for the stainless steel bumper inserts and production numbering. As you look over the car you will also be entertained by Steeda Sidewinder striping and Graphic Express decals. Enjoy!
BlockFront Suspension
Cylinder HeadsSteeda Sport
CamshaftsTokico five-way adjustable
Intake ManifoldMOMO Sport 18x85
Throttle BodyToyo Proxes T1-S 245/40 ZR18
Power AdderBrakes
Vortech S-Trim (12 psi)Stock w/ stainless brake lines,
ExhaustPower Slot rotors, and HP Plus
Sean Hyland Motorsport long-Hawk pads
tube headers and H-pipe w/ BorlaRear Suspension
ZR-1 mufflers and tailpipesSprings
Fuel SystemSteeda Sport
Vortech inline pump with 42-lb/hrShocks
injectorsTokico five-way adjustable
TransmissionTraction Devices
SHM-prepped T56; King CobraSteeda adjustable rear sway bar
RearendMOMO Sport 18x10
8.8 w/ 3.73 gearsTires
 Toyo Proxes T1-S 275/23 ZR18
Engine ManagementBrakes
Paul's Automotive Engineering-Stock calipers, Power Slot rotors,
tuned Autologic chipHP Plus Hawk pads
IgnitionChassis Stiffening
MSD DIS-4, SHM dual coils,Steeda G-Trac bar, Steeda strut-
FRPP 9mm wires, Autolite plugstower brace, Maximum
GaugesMotorsports full-length
Auto Metersubframes, Kenny Brown six-point
