Michael Johnson
June 1, 2003
Photos By: Steve Turner
Engine And Drivetrain
BlockR302
Bore4.080
Displacement310
CrankshaftEagle 4340
Connecting RodsEagle H-beam
PistonsCP
Cylinder HeadsTrick Flow Twisted Wedge, Crower roller rockers
Intake ManifoldTrick Flow Street, Accufab 70mm throttle body
Mass AirPro-M 75mm Bullet
Fuel SystemWeldon 2015A pump, Behind Bars Race Cars fuel rails, MSD 50-lb/hr injectors
Power AdderPaxton Novi 2000, Mark Magnuson special 4-in inlet pipe
TransmissionHanlon pro-shifted TTC-Tremec TKO-II, Steeda Tri-Ax shifter, Spec Stage III, Ram aluminum flywheel
Rearend8.8 Ford, FRPP cover, Moser 33-spline gun-drilled axles, 3.55 gears
Electronics
Engine ManagementStock computer, Autologic chip
IgnitionMSD Digital 7
GaugesAuto Meter
Suspension And Chassis
Front Suspension
K-MemberD&D tubular
Caster/Camber PlatesBBK
SpringsCut four-cylinder
StrutsCompetition Engineering 90/10
WheelsWeld Draglites
TiresMoroso DS-2
BrakesAerospace
Rear Suspension
ShocksQA1 12-way adjustable
Springs'01 GT convertible
Traction DevicesTRZ lowers, double-adjustable uppers, antiroll bar, spherical rod ends
Rollbar10-point
Rear TiresMickey Thompson 26x10
BrakesStock drums
