003 Snap Shots Zach Penn 2003 SVT Cobra
March 19, 2018
Houstonian Zach Penn is the owner of this gorgeous Zinc Yellow 2003 SVT Cobra convertible that he purchased in July 2004. A complete street car with every factory amenity, it has a built motor from Excessive Racing Engines out of Pearland, Texas, maintaining the factory heads and cams for drivability. Topped with a supercharger and with the boost turned down to a street-friendly 26 psi, the car makes a healthy 855 rwhp.. Other modifications include a built T-56 transmission connected to an MGW shifter, a Lethal return-style 1,400hp fuel system running e85, J&M adjustable rear lower control arms with Eibach springs, Brembo 14-inch rotors and six-piston caliper big brake kit, a McLeod RXT twin disc clutch, and a PNR trunk-mounted ice tank with a Rule 2,000 pump. Other modifications include a tubular K-member and A-arms with coilovers, as well as a solid rear axle from a 2004 Mach 1.
