Steve Baur
October 17, 2013
Photos By: Drew Phillips
After that round of modifications, the Ranchero found itself in the capable hands of Ford Auto Body, which made sure the panels were straight, smooth, and slathered in a vibrant Sunrise Orange Mist hue. While Ford Auto Body would get the car last to hang the sheet bolt on sheetmetal panels, Bruce and his team got to work installing the wiring, interior, drivetrain, and more.
When Bruce thought up the Boss theme, it wasn't just a stripe package. At the start of the project, he contacted Don Barrington of Barrington Engines (Van Nuys) for a suitable powerplant. As it turned out, Don had a 351C 4V that had been sitting for a few years. It was a dirt track engine that was built, more or less, to Boss 351 specs but with a bigger cam. Backing the Cleveland is a Top Loader that Bruce and his staff stuffed with high-end parts from David Kee Top Loader Transmissions Inc (San Antonio, Texas).
The suspension wasn't left alone either, as Maeco Motorsport's full floating leaf springs with Heim joints articulate the 9-inch rearend, while Total Control Products coilovers put the wheels to pavement at the front.
"We got the car back from paint about three weeks before the show," Bruce recalled." "We worked about 18 hours a day for seven straight days—there was a lot of Starbucks and Red Bull."
Arriving at the SEMA show with no time to spare, Bruce had only put about four miles on the Ranchero, which isn't a problem for a static show car. It became a problem when the Optima Batteries staff chose the car to take part in its annual Optima Ultimate Street Car Invitational. To participate in the event, you first have to drive in a parade around Vegas, then perform a scavenger hunt of sorts before driving out to the track in Pahrump, Nevada. After some minor issues, the Ranchero completed the driving tasks in time for the event the next day. The untested Ford managed to complete a few of the tests, but eventually Bruce had to opt out of the event.
Since then, the Ranchero has turned many a lap at Willow Springs, it's been to a number of shows, including the LA Auto Show, and Bruce told us he often uses it for parts runs at work.
"It's decent on street and it's on rails at the track," Bruce noted.
With the Herculean efforts of Manny Gonzales and Ray Petrossian, Bruce and Galpin Motors pulled off quite the build in such a short amount of time and in the process, proved that this really is a Boss that hauls, in more ways than one.
Bruce Schureman's '68 Ranchero
Engine
'70 351 Cleveland four-bolt-main block
4.00-inch bore
3.50-inch stroke
Stock Ford crankshaft, heat-treated, polished and chamfered
Stock ford connecting rods, shot-peened, polished, resized for ARP hardware
Diamond forged aluminum pistons with Speed-Pro rings
Stock Ford 4V cast-iron cylinder heads, 2.190-inch intake/1.710-inch exhaust valves, Comp Cams springs and push rods, Ford Racing Performance Parts 1.73:1 roller rocker arms
Clay Smith mechanical flat-tappet camshaft, 292/292-degree duration, 0.570/0.570 valve lift
Stock Ford cast-iron intake manifold, port matched with plenum modified
Holley Ultra HP 750-cfm carburetor
Pertronix Flamethrower billet distributor
Engine built by Barrington Engines (Van Nuys, CA)
10.4:1 compression ratio
Exhaust
Ford Powertrain Application performance-coated long-tube headers
3-inch exhaust tubing with X-pipe by Gil's Muffler (Reseda, CA)
Dynomax Race Bullet resonators
Spin Tech mufflers
Transmission
Ford Top Loader four-speed
Hurst Competition Plus shifter
McLeod Racing RXT twin-disc clutch with aluminum flywheel
Rearend
Currie Enterprises 9-Inch
Traction-Lok differential
3.89 gears
Suspension
Front: Total Control Products coilover with VariShock dampers, Maeco Motorsports adjustable front antisway bar
Rear: Maeco Motorsports full-floating rear leaf spring system, Maier Panhard bar, VariShock adjustable dampers
Brakes
Front: Wilwood disc, Superlite four-piston calipers, 13-inch rotors
Rear: Wilwood disc, Superlite four-piston calipers, 12-inch rotors
Wheels
Front: American Racing VN427 Shelby, 17x9
Rear: American Racing VN427 Shelby, 17x9
Tires
Front: Nitto NT05, P315/35ZR17
Rear: Nitto NT05, P315/35ZR17
Interior
Auto Custom Carpet, custom rollbar, Procar Elite bucket seats, Simpson five- point harnesses, Lecarra Mark 3 Supreme steering wheel with Boss 351 horn button
Exterior
PPG two-stage custom Sunrise Orange Mist paint by Galpin Auto Sports, Maeco Motorsports, and Ford Auto Body; custom-fabricated hood with functional ram-air ducting; modified Shelby R model front fascia; Trans Am-style fender reverse fender flares; custom aluminum tonneau cover with spoiler fabricated by Ray Petrossian
