Barry Kluczyk
August 22, 2013
By the late-2000s, the aesthetic for modified cars had changed from ladder bars clamped to the axle and chrome velocity stacks pushing through the hood, and Bard rightfully went the restomod route, finally putting dreams of metal-flaked paint and a crushed red velvet dashboard out of his head. In there place is the appearance of a nicely restored Mustang that, upon closer inspection, reveals a number of clever details. The color, for instance, isn't Grabber Orange; it's a Lamborghini color with a pearlescent quality that has to be viewed from different angles to fully appreciate it. And the Mach I Shaker scoop isn't an original '70 piece, either. It's from the 2003 model. The scoop has been modified to accept the air inlet for a Paxton-blown 351.
The RideTech air suspension is another of the car's signature features and Bard claims his was one of the first Fords to be equipped with one.
"It was an interesting process adapting it to the car," he says. "I'd call them for technical assistance, but it seemed I was giving them back as much technical advice on the installation for Mustangs as they were giving me in general for the system itself."
You'd think that after nearly 35 years that Bard wouldn't have felt rushed to complete the car, but by early 2011 he was feeling the squeeze of getting it to the Motor City for the Detroit Autorama—one of the largest and most prestigious indoor car shows.
"There was an all-nighter to get it finished, just like you see on one of those cable TV shows about building cars," he says. "With the help of a bunch of good friends, the car was loaded on a trailer at 7 a.m. and delivered to Detroit, where it won its class. Three weeks later, it was named the Best Ford and one of the Top 10 overall at Toronto Speedworld."
The awards have kept coming, too, as Bard and the Mustang take home a trophy at just about every event they attend. That's quite a few, too, because the car is a driver and the owner enjoys exercising its more than 700-horse supercharged engine and banging through the gears of the Top Loader transmission behind it. We simply don't have the space on these pages to show every last detail, but believe us, the underside is as sanitary as everything within eyeshot.
It's also the perfect calling card for Bard's restoration services, exemplifying craftsmanship, creativity, and excellent attention to detail. He swears, too, that customer projects don't take 30 years to complete!
Mark Bard's 1970 Ford Mustang Mach I
Engine
Ford '71 Boss 351 (0.030-in. overbore)
4.030-inch bore
3.500-inch stroke
Ford Boss 351 crankshaft
Ford Boss 351 connecting rods (shot-peened), 5.780-inch-long
Speed-Pro forged aluminum pistons
Speed-Pro piston rings
10.1:1 compression ratio
Edelbrock Performer RPM cylinder heads ported by Mark Bard
Custom-grind Comp Cams roller camshaft with 0.576/0.576-inch lift and 290/290-deg. duration
Comp Cams roller lifters and pushrods
Comp Cams 1.72-ratio rocker arms
Edelbrock Performer RPM aluminum intake manifold
Demon 750-cfm "double-pumper" carburetor
Paxton Novi supercharger pushing 12 pounds of boost
MSD ignition system
Classic Auto Air air conditioning system
Aeromotive fuel system
709 hp at 6,600 rpm
574 lb-ft at 6,200 rpm
Dyno testing conducted at Leitch Performance, Windsor, Ontario, Canada
Transmission
Top Loader four-speed
McLeod dual-disc clutch
Modified V-gate shifter (moved back 6 inches to clear dashboard)
Rearend
Ford 9-inch N-case housing (shortened)
3.89 gears
Ford Traction-Lok differential
31-spline axles
Exhaust
Hedman ceramic-coated headers, 13⁄4-inch primary, 3-inch collectors
Custom 3-inch exhaust system by Mark Bard
Spin Tech mufflers
Custom "zoomie" exhaust outlets in front of rear wheels
Suspension
Front: Global West upper and lower A-arms and RideTech ShockWave air-over-shock height-adjustable dampers
Rear: RideTech ShockWave air-over-shock height-adjustable dampers
Steering
Flaming River rack-and-pinion
Tilting steering column
Brakes
Front: '70 Ford Mustang 11.25-inch discs
Rear: 11-inch discs (Ford Racing drum-to-disc conversion kit)
Wheels
Front: American Racing 200S, 15x8
Rear: American Racing 200S, 15x10
Tires
Front: Mickey Thompson Sportsman S/R 26X10.00R15LT
Rear: Mickey Thompson Sportsman S/R 28X12.00R15LT
Interior
Original-style with custom center console for shifter and RideTech suspension controls; Eagle Talon front seats; leather and cloth upholstery by Mr. B's Custom Upholstery, Coatsworth Station, Ontario, Canada; Auto Meter instruments in factory gauge locations
Exterior
Lamborghini orange color; '03 Mustang Mach I Shaker scoop; Tri Bar headlamps, factory lower Mach I rocker molding eliminated for cleaner appearance; body- and paintwork performed by Southwest Coatings & Finishings, Tilbury, Ontario, Canada
