Steve Dulcich Contributing Editor
October 8, 2015
Photos By: Brandan Gillogly
When legendary AMSOIL Engine Masters participant Jon Kaase considered the new Vintage V8 Class for the 2015 Challenge, he contemplated engine possibilities with the cold pragmatism of a serious competitor. One of the key requirements from Kaase’s perspective was the availability of an aluminum cylinder head. As Kaase explains, “An aluminum head allows almost unlimited modifications, and in an unlimited class like this year’s Vintage category, we wanted a head that can be machined and welded or modified.” Topping the Mummert heads is a custom adapter mating the heads to a tall Edelbrock small-block Chevy tunnel ram. The bottom end was built with a Bryant billet crank, Carrillo rods, and custom Diamond pistons. The result is a 400ci engine putting the squeeze on the mix at a 13.9:1 ratio. To work with the mushroom-tappet arrangement of the Ford Y-block, custom lifters were manufactured by Trend, with a Comp Cams billet flat tappet orchestrating the movement. Kaase custom-fabbed a long set of tri-Y headers and installed an MSD ignition system to light it off.
So what is the effect of all of these mods on this ancient Ford? How about numbers that would leave any builder of the latest hardware slack-jawed at the results. Torque started off strong at 526 lb-ft at the 3,000 rpm bottom of the test range, and twist only ramped up from there. Peak torque recorded measured 596 lb-ft at 4,600 rpm. On the power side, Kaase didn’t disappoint, with peak output showing 584 hp at just 5,500 rpm. That was plenty of power and torque over the rpm range to net a class-topping score. With most of the field behind him, Kaase looks like the safe bet to take home the vintage class win.
Engine Builder: Jon Kaase
Engine Type: Ford Y-Block
Claimed Displacement: 400 ci
Block: Factory cast iron
Compression Ratio: 13.9:1
Crankshaft: Bryant
Connecting Rods: Carrillo
Pistons: Diamond
Rings: Total Seal
Camshaft: Comp flat-tappet 244/238 duration
Cylinder Heads: Mummert
Intake Manifold: Edelbrock 7110 small-block Chevy tunnel ram
Carburetor or EFI system: Two Holley 750 cfm
Headers: Dynatech 1-7/8 to 2-inch stepped tri-Y
AMSOIL Oil: 10W40
Average Peak Horsepower Over Three Pulls: 583 hp
Average Peak Torque Over Three Pulls: 594 lb-ft
See every engine, dyno run, and behind the scenes action of The 2015 AMSOIL Engine Masters Challenge
Thanks to the High-Performance Division of the University of Northwestern Ohio for hosting AMSOIL Engine Masters Challenge!
