Jeff Ford
August 1, 2002
Steering:
* Power-assisted rack-and-pinion.
* Overall ratio 15.3:1 on center.
* Turning Diameter, Curb-to-Curb-38.1 ft.
Brakes:
* Front calipers aluminum dual piston, custom anodized painted.
* Rotors-330 mm (13 inches) Brembo vented.
* Rear calipers single piston.
* Rotors-296 mm (11.7 inches) Brembo vented.
* ABS/T.C.-Yes.
* Miscellaneous-Subframe connectors.
Interior:>
* Optional stainless steel pedal covers are positioned to provide better heel-to-toe relationship.
* Unique dash panel and custom gauges.
* Unique Mach 1 seats with leather centers designed to appear like '69-'70 Comfortweave.
* Custom aluminum shifter ball.
Power Team Specifications 2003
Engine Type MOD 4.6L DOHC V-8
Displacement 4.6L, 281 ci
Horsepower @ rpm {{{300}}}+ @ 6,000 (projected)
Torque lb-ft @ rpm 300+ @ 4,250 (projected)
Compression Ratio 10.1:1
Bore x Stroke {{{90}}}.2 mm x 90 mm
(3.55 in. x 3.54 in.)
Fuel System Sequential
(91-octane minimum)
Fuel Requirement Premium (91-octane minimum)
Exhaust System Stainless steel with chromed rolled tips
Transmission
Type five-speed manual or four-speed automatic
Final Drive Ratio 3.55:1
Gear Ratios (Manual) First-3.38;
Second-2.00;
Third-1.32;
Fourth-1.00;
Fifth-.{{{62}}};
Reverse-3.38
