Tom Wilson
March 2, 2012
2012 Boss 302
Engine and Drivetrain
Block Coyote aluminum
Crankshaft Forged steel
Rods Forged steel
Pistons Forged aluminum
Camshafts DOHC w/Ti-VCT operating range of 50 degrees for intake and exhaust
Cylinder heads DOHC, four valves per cylinder, variable intake, variable camshaft timing
Intake manifold Composite shell-welded with runner pack
Fuel System Sequential mechanical returnless
Exhaust Stainless steel tubular headers, quad exhaust tips
Transmission Getrag MT82 six-speed manual
Rearend 8.8-inch axle w/ Torsen T2R limited-slip, and 3.73 gears
Electronics
Engine management Copperhead (Trackey optional)
Ignition High-energy coil-on-plug
Gauges Stock
Suspension and Chassis
Front suspension
A-arms Reverse-L lower
Struts MacPherson, adjustable damping
Brakes 355mm (14-in) x 32mm vented discs, and four-piston Brembo 40/44mm fixed aluminum calipers
Wheels 19x9-in wide-spoke painted aluminum wheels
Tires Pirelli PZero 305/645-18 racing slicks
Rear suspension
Shocks Adjustable
Brakes 300mm (11.8-in) x 19mm vented discs, single-piston 43mm floating iron calipers, and Performance Friction Compound pads
Wheels 19x9.5-in wide-spoke painted aluminum wheels
2012 Boss 302S
Rods Forged steel
Fuel system Sequential mechanical returnless
Exhaust Stock Tri Y manifolds w/ Bassani 3-in X-shape crossover
Transmission Tremec 6060 six-speed manual w/ custom aluminum/carbon clutch and flywheel
Electronics
Engine management Sealed Ford Racing ECU
Gauges AIM MXL Strada High Performance Digital Dash
Front suspension
Tires 255/40R-19 Pirelli PZero max performance
Rear suspension
Shocks Adjustable
Brakes Four-piston Baer Brakes w/ floating Brembo rotors
Wheels 18x10-in BBS
Rear suspension
Shocks JRZ dampers w/ ERP valving
Control ArmsStock
Wheels 18x10-in BBS
