Steve Turner
August 1, 2004
Photos By: Courtesy of Ford Motor Company
As have you, we've been wondering what the '05 Mustang would look like as a race car. While we'll have to wait to see it with skinnies and slicks for the dragstrip, Ford has taken the guessing out of what a road racer will look like. Inspired by the successful '70 Boss 302 Trans Am cars, the '05 Mus-tang GT-R is a purpose-built race car designed to celebrate the way owners have long modified Mustangs for performance. The car was unveiled at the New York Inter-national Auto Show, a little more than a week before the big 40th Anniversary show in Nashville.
Obviously produced to get the Mustang faithful excited, it certainly works as far as we are concerned. Better yet, it may be a harbinger of things to come. "The Mustang GT-R blends today's breath-taking design, Ford Racing's unmatched history, and the most advanced racing technology into the ultimate Mustang," J Mays, Ford group vice president of design, said. "Mustang's iconic image grew with every checkered flag, so we think the Mustang GT-R is an appropriate tribute to the car's 40th anniversary, and a hint at what's to come."
Since Ford is touting the GT-R as a return to the company's road racing and 5.0 roots, we're hopeful this car could not only be the sign of a turnkey, grassroots racing program they've hinted might be available through FRPP, but also the return of the Boss 302 of which we've been dreaming. Time will tell, but one thing's for sure-the '05 Mustang GT-R concept is sure to get us all juiced about hot-rodding the real thing when it debuts later this year.
Block V-8, aluminum block
Heads Aluminum Four-Valve
cylinder heads
Pistons Forged aluminum pistons
Bore x Stroke 94mm bore x 90mm stroke
Displacement 5.0 liters (302 ci/4,995 cc)
Compression Ratio 11.0:1
Horsepower 440 at 7,000 rpm
Torque 400 lb-ft at 5,500 rpm
Redline 7,000 rpm
Valvetrain Double overhead
camshafts, four valves per cylinder
Intake Valves Two per cylinder, 38 mm
Exhaust Valves Two per cylinder, 32 mm
Throttle Body Twin {{{57}}} mm
Transmission FRPP/Tremec T56 six-speed
Rear Axle Winters/Ford 9-in design
Differential Winters race-spec
rear differential w/4.56 gears
Clutch FRPP Cobra R heavy-duty
clutch/flywheel assembly
Driveshaft Metal matrix composite
aluminum custom driveshaft
Exhaust Complete stainless steel race exhaust w/Tri-Y design headers,
crossover and side exit tips
Chassis Fully reinforced fabrication
Suspension Original production geometry with lightweight chrome-moly tube
(aircraft quality) construction
Front Reverse-L independent rigid
strut tower brace w/lightweight
chrome-moly K-member and
race-spec antisway bar
w/1.25-in box section
Rear Three-link, solid axle w/dynamic,
fully adjustable shocks w/remote
reservoirs and coilover springs,
race-spec 1.25-in Panhard rod,
and race-spec antisway bar
Front Brembo Racing six-piston calipers
and 14.3-in rotors, 1.25-in thickness
Rear Brembo Racing four-piston calipers
and 13-in rotors, 1.25-in thickness
Front Pirelli P275/35/20 racing slicks
20x10-in, five-spoke billet-aluminum wheels
Rear Pirelli P315/30/20 racing slicks
20x11-in, five-spoke billet-aluminum wheels
